Click for Crusader parts and manuals!
Results 1 to 6 of 6
  1. #1
    Default how to winterize a 8.1L Crusader ho 425hp inboard engine
    trying to get a jump on things here....my mechanic is out of service...and would like to winterize my 41 1991 silverton myself this year....detail is important ...I do oil changes but never did winterized the motors.
  2. #2
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    7,086
    Default Re: how to winterize a 8.1L Crusader ho 425hp inboard engine
    what you need to do will depend upon where you are located. Start with your engine owner's manual. You can also search "winterize" on this forum...many excellent posts with time saving tips.
  3. #3
    Join Date
    Jul 2010
    Location
    Canada
    Posts
    631
    Ditto Mark. Every application has it's differences, and the last thing you want to do is miss something not touched on here. Here's my take; there are so many posts at the beginning of the season that eventually turn out to be cracked blocks and manifolds. I suspect mostly due to improper wintering. If you have to ask how to do it (no offence here), then it's probably something you shouldn't attemp just yet. You may consider (I've done this for several) hiring someone to winterize and show you as he's doing it. This way, there's a better chance that everything will be covered and that you're better prepared for next year....take notes and pics. You really have to wiegh the cost of hiring someone versus the cost of possibility replacing an engine.
  4. #4
    Join Date
    May 2008
    Location
    Glen Head, NY, USA
    Posts
    364
    I live in downstate New York. I watched and helped someone do it twice before on another boat I had. I read and followed many posts. On my FWC twin 454 1991 carb'ed engines, I use a 5 gal bucket full of 5 gals pink antifreeze and remove hoses from sea strainers and suck up the pink stuff. I join the hose to a longer hose to reach the bucket. During the last 2 gals I spray fogger into the carb. I have my son at the exhaust looking for "pink" to be seen exiting. He is verifying the white smoke too. Its hard to see the smoke on windy days. You have to be able to sleep at night all winter.
  5. #5
    Join Date
    Oct 2009
    Location
    New Haven, CT, USA
    Posts
    601
    When I did mine for the 1st time a couple of years ago with my wife (she watches the exhaust), it somehow came up in the dead of winter that one side was "a little more pink than the other". Great feeling for the next 3 months.
    Now when she says it's "bright pink", I let it run for another 30 seconds
    Bob
  6. #6
    Join Date
    May 2008
    Location
    Glen Head, NY, USA
    Posts
    364
    You have to sleep at night. Hard to talk about wintering in august.
Similar Threads
  1. Raw water engine winterize
    By jeffnoank in forum Mercruiser Sterndrive Forum
    Last Post: 09-15-2010, 05:46 PM
  2. Canbt winterize my starboard engine wonbt start
    By bobct in forum Crusader Marine Engine Forum
    Last Post: 12-04-2009, 07:55 PM
  3. Should I winterize my engine
    By 89sea65ray in forum Mercruiser Sterndrive Archive
    Last Post: 11-04-2007, 07:31 PM
  4. Winterize and fogging engine
    By ceeclipz in forum Mercruiser Sterndrive Archive
    Last Post: 10-26-2007, 06:51 PM
  5. Need help identifying inboard engines 1981 Chev Crusader
    By writeofway in forum Other Gas Inboard Mfgs IO and Sterndrive Questions
    Last Post: 07-12-2006, 11:18 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
