1981 Chrysler 85 hp engine will not run
While trolling the engine died and would not start. Took into my shop and started to check it out, trying new fuel, check the spark at each plug, it is good. checked compression it is 140 lbs each cylinder. Plugs are new. Battery cranks great. Checked timing by turning crank to tdc then pulled distrubitor cap to varify rotor pointing at #1 OK. Motor is getting fuel. Any suggestions.
Maybe the flywheel key?
Check gas for water?
Ethanol is delaminating the inside of older hoses.They will collapse and shut off flow.
Check for any soft/mushy hoses.
Check fuel pump diaphram.
Profile?
