Results 1 to 9 of 9
  1. #1
    Default alpha 1-cruising along then engine revs up,no prop turn.
    from stop, goes into gear fine, rev to 2000 rpm, then revs high but no prop spin? thinking maybe prop rubber letting go/ any ideas, leg and gears seem lovely...thx wellcraft
  2. #2
    Join Date
    Jun 2009
    Location
    New Plymouth,Taranaki,New Zealand
    Posts
    287
    Default Re: alpha 1-cruising along then engine revs up,no prop turn.
    try yr spare prop,c what happens
  3. #3
    If not your prop, you could have spun the rubber hub on the engine coupler.
  4. #4
    Quote Originally Posted by seabaymarine View Post
    rubber hub on eng coupler? the shaft from motor to prop is all gears.runs great out of the hole till 2000rpm.doesnt the leg shaft connect solidly to the flywheel(crankshaft)?and if there is a rubber coupler there wouldnt it just spin even on idle? thx wellcraft
  5. #5
    Quote Originally Posted by budgie14 View Post
    props coming off in the am..we'll see ? but if looks ok? try a demo i guess. wierd that it would stay together till around 2000rpm. its a stainless with manufacturer pressed rubber with copper sleeve, not a removeable hard plastic collar..???????? first ive come across in 20+ yrs......
  6. #6
    Join Date
    Dec 2006
    Location
    Chaumont Bay, N.y., USA
    Posts
    5,421
    Ayuh,... It's either the Prop, or the Coupler...
    The coupler mounts to the flywheel, 'n the drive slips into it...
  7. #7
    Join Date
    Jul 2010
    Location
    Canada
    Posts
    631
    Ditto, coupler or prop. It is not a solid all metal connection from engine to drive. There is rubber involved just like the prop. Hope it's the prop, unfortunately, youhave to remove the engine to get to the coupler.
  8. #8
    thx to all....its the prop....now to find a pressed hub for a 1990 stainless, lol, book shows removable..CHEERS
  9. #9
    Join Date
    Aug 2006
    Location
    SW Ohio, USA
    Posts
    10,396
    A good prop shop may be able to fix it.
Similar Threads
  1. 1996 alpha 3.0 steearing will not turn right
    By stevesoy in forum Mercruiser Sterndrive Forum
    Last Post: 08-01-2011, 12:41 PM
  2. Safe cruising revs
    By davesboat in forum Volvo Penta Gas Engine Forum
    Last Post: 03-15-2010, 05:48 PM
  3. Mercruiser 50 Alpha Shuts down while cruising wakeboarding
    By cosmo in forum Mercruiser Sterndrive Archive
    Last Post: 07-24-2007, 12:12 AM
  4. Engine Revs Prop slipping Milky Oil through the impeller Shaft
    By seattle_cargile_28 in forum Volvo Penta Gas Archive
    Last Post: 12-18-2006, 09:26 AM
  5. Replies: 3
    Last Post: 05-27-2003, 10:47 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
