" The tachometer attached to m
" The tachometer attached to my 1986 DT115 gives extraneous readings. For instance it rarely reads less than 4400 rpm when I suspect it should be around 3500. When the speed is increased, it will fall to around 4000 rpm. Where could the extraneous signal be coming from? "
