Results 1 to 3 of 3
  1. #1
    Default 1976 Johnson 35 hp electric start, converting to a tiller steer, no spark
    I aquired this motor and the remote cable was cut, I converted it to a tiller steer and got my throttle hooked up. I rigged up a push button starter. I still have the other end of the remote plug and around 4 feet of wire. The wire colors on remote wire are black, black w/ yellow stripe, purple w/ white stripe, yellow, red w/ purple stripe. I am not getting fire at my spark plugs, and I'm guessing it has something to do w/ the remote plug. Has anyone ever made a conversion like this? Any help is appreciated!!
  2. #2
    Default Re: 1976 Johnson 35 hp electric start, converting to a tiller steer, no spark
    Figured out my problem, wasn't the wiring, cleaned and gapped the points, works perfect.
  3. #3
    Quote Originally Posted by HollinKY View Post
    I would like to do the same to my 1976 (I believe) 35 hp electric start Johnson. Any help you could give me would be greatly appreciated. Thanks, Bob
Similar Threads
  1. Converting a pull start outboard to an electric start
    By tomiller97 in forum Mercury Mariner Outboard Archive
    Last Post: 12-05-2008, 06:18 PM
  2. Converting from tiller to front steer
    By mike_lee in forum Nissan Tohatsu Outboard Archive
    Last Post: 02-19-2008, 10:32 PM
  3. Converting from tiller to front steer
    By mike_lee in forum Johnson Evinrude Outboard Archive
    Last Post: 02-16-2007, 06:56 PM
  4. Converting manual b86 30hp Evenrude to electric start with b88 20 hp Johnson starter
    By martman in forum Johnson Evinrude Outboard Archive
    Last Post: 05-08-2003, 11:18 AM
  5. Converting 1996 25hp Johnson pull start to electric
    By jerry in forum Johnson Evinrude Outboard Archive
    Last Post: 04-19-2003, 09:41 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
