MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 6 of 6
  1. #1
    Default 1996 40hp mercury/force
    hi all. im looking at a boat with a 1996 merc/force 40hp. how are the force motors made by merc? do i want to stay away from these motors? are the parts from the force able to switch in and out of a mercury 1996 40hp or are they the same parts?
  2. #2
    Join Date
    Sep 2003
    Location
    New Tripoli, PA, USA!
    Posts
    15,325
    Default Re: 1996 40hp mercury/force
    I think that's a Chrysler.
    Jeff
  3. #3
    nope mercury bought force in the early 90s. it says force made by mercury right on the hood cover
  4. #4
    Join Date
    Sep 2003
    Location
    Posts
    15,325
    True, but every one I've seen was a Chrysler.
    Jeff
  5. #5
    Join Date
    May 2007
    Location
    Inverary, Ontario, Canada - The Great White North Eh!
    Posts
    9,114
    I would stay away unless the price was "exceptional".
    Yes, Merc did own Force but here's the story.
    In the mid 1980's when Chrysler was circling the toilet, Bayliner boats bought out their outboard division - machines, patents, parts - the whole shebang and gave it to their own U.S. Marine division.
    Their plan was to build their own motors to package with their boats and keep the price point low. They first called the motors Force by Chrysler and after a year or two dropped the Chrysler part. However, the motors were built pretty much to pure Chrysler specs.
    In 1986, Brunswick (a giant in the marine industry) bought out Bayliner, getting the U.S. Marine division as part of the deal. Since Brunswick already owned Merc they had no desire to keep two separate outboard companies and basically rolled Force into the Merc line.
    At the time Merc was already having Yamaha produce a "budget line" of motors for them which were being sold under the Mariner brand. These Yami/Mariners were 100% Yamaha, but were generally older technology that Yami had either stopped producing themself or did not contain the bells/whistles of the models with Yamaha decals on them.
    Force became the "sub-budget" line at Merc. There was thousands of Chrysler parts still in inventory and likewise, Merc had thousands of parts they were no longer using on "their" own models which are almost always at the "leading edge".
    So "Mercs" Force line gave them the golden opportunity to get rid of everything sitting around with dust on it.
    That 40 Force which was built in 1996 has Tillotson carbs on it which Merc stopped using in the late 1970's (and parts are getting very very scarce - most "kits" do not contain everything you need because the supplies are simply no longer there, so every couple years the kits get smaller). And while this particular model did not have the Prestolite (Chrysler) ignition (which actually would have been an advantage since you can still get parts for them), it used an early Merc CDM ignition for which the CDM module and the trigger is long discontinued and no longer available.
    Anything the Merc was no longer using on their own motors got cobbled into the Force models.
    There was a reason that a 40 Force sold for about 60% of the cost of a 40 Merc and about 80% the cost of a 40 Mariner. Most were built as "disposable" motors.
    Now that is not true of every model, some still have decent parts support - the 40 Force which was a Chrysler/Merc hybrid (for it's entire model run) was just not one of those models.
    If it runs now and it was taken care of, it may last a number of years - but if something goes "flooey" you have nothing more than a couple hundred pounds of scrap aluminum.
    So don't kid yourself - they were "produced" by Merc, but they bear no resemblence and are no longer supported.
    Graham
    A "professional" is someone who gets paid for their work - it doesn't necessarily mean they are good at it :)
  6. #6
    Join Date
    Sep 2003
    Location
    Posts
    15,325
    Excellent write up (as expected from Sir Graham!)
    My buddy has a Force (Chrysler) 50 HP twin that starts and runs great (though it shakes a bunch as low speed. A minimum of 3 cylinders is needed for that much hp.) So far it hasn't needed a thing, but....
    Jeff
Similar Threads
  1. '1996 Mercury - Tracker 40hp
    By JonBoy78 in forum Mercury Mariner Outboard Forum
    Last Post: 10-25-2010, 10:07 PM
  2. 1996 mercury force question
    By zebbman in forum Mercury Mariner Outboard Forum
    Last Post: 07-25-2010, 09:07 PM
  3. 40hp Force Mercury Water in Cylinder Problem
    By bobdie in forum Mercury Mariner Outboard Archive
    Last Post: 06-24-2009, 12:35 AM
  4. 1996 Force 40hp getting water in the cylinders
    By overboardmarine in forum Chrysler Force Outboard Archive
    Last Post: 07-12-2008, 03:47 PM
  5. Where is the taletale hole on a 1993 40hp Force by Mercury
    By flatlander2000 in forum Mercury Mariner Outboard Archive
    Last Post: 07-16-2006, 06:02 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
