MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 4 of 4
  1. #1
    Join Date
    Jul 2011
    Location
    land o lakes florida
    Posts
    30
    Default 3 bladed prop vs 4 bladed prop?
    Hi everyone, have a question about 3 bladed vs 4 bladed prop, whats the difference as far as performance. Heard that a 4 bladed could slow you down a bit , is this true? Thanks!
  2. #2
    Default Re: 3 bladed prop vs 4 bladed prop?
    I have the same question , but I have heard that a 4 blade gets the boat on plane quicker .... I dont think it will be slower than a factory prop .... no flex in the stainless steel alone will make it better than stock .IMO
  3. #3
    Join Date
    Mar 2011
    Location
    northern IL.
    Posts
    79
    The 4 blade prop will get you on plane quicker if your boat weight is heavy or loaded near max. You might lose 1 or more mph. by using a4 blade. I don't recamend stainless if the usage is on water that is other than a lake, because if one hits a submerged obstical the chances of lower unit damage increse and the cost of a lower unit repair can be expensive.
  4. #4
    I have a 175 pro XS. They don't make aluminum props for my motor. I'm stuck with stainless.
Similar Threads
  1. Duo prop to single prop question
    By glastron24css92 in forum Volvo Penta Gas Archive
    Last Post: 07-23-2009, 12:39 PM
  2. Prop install and prop size
    By birdy916 in forum Mercruiser Sterndrive Archive
    Last Post: 06-10-2009, 07:20 AM
  3. Volvo Penta Duo Prop DPS Prop Installation
    By njfishing in forum Volvo Penta Gas Archive
    Last Post: 04-30-2009, 10:05 AM
  4. Prop
    By f300k in forum Volvo Penta Gas Archive
    Last Post: 07-16-2008, 10:34 PM
  5. Trying to determine diameter and pitch of prop on 85HP Johnson from number stamped on prop
    By Bob Padowicz in forum Johnson Evinrude Outboard Archive
    Last Post: 07-29-2006, 11:27 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
