Hello everone , Need some help !! I have driven myself mad and pritnear broke trying to solve this issue. 302 with a 2bbl Holley, I have rebuilt the carb completely, and have changed out everything , in every possible configuration,cleaned and assembled at least 40 times (seriously), now the gaskets are history, accelerator pumps, power valves, jets, squirters, It allways stumbles from 500 rpm to 1000, once you put it into forward it stumbles ( like its starving) and quits, after 1000 it works great, if you give it a quick shot it works fine, but you don't dare do that in the channel, today I installed a mallory distributor with a Pertronix flamethrower conversion kit, coil,cap ,rotor,wires and A/C MR43T plugs and gap of .40 10 degrees adv. total 28. Did voltage tests, vacuum leak tests , gauge does fluctuate 17-20 . compression is in the 125 range, no missing or any other issues. prem. fuel. I just can't seem to get it ! intake gaskets ? weak fuel pump? I'm almost certain its the carb but i don't have another to try or the 350.00 for a reman. If there is a WIZARD out there could you help, I'm going in to get a couple Advil and will come right back. Thanx David.
