Results 1 to 7 of 7
  1. #1
    Join Date
    Aug 2008
    Location
    Charlotte, nc,
    Posts
    82
    Default mercruiser gm 350 need diagram for alternator hookup
ID:	2805Click image for larger version.
ID:	280687 wellcraft / Click image for larger version.
ID:	2807Click image for larger version.
ID:	2807 350 / IV breakerless ignition
    i have the shop book. but the wiring to the alternator is not totally clear to me. I have the orange in the right place. need to know where the purple/red and purple wires connect. a picture would be superb.
    also want to see a pic of starter wiring. I forgot to lable them when I pulled the engine this time. Just wanna make sure i dont fry somthing.
    thanks
    Dan
  2. #2
    Join Date
    Jul 2008
    Location
    Northboro, Ma, USA
    Posts
    4,788
    Default Re: mercruiser gm 350 need diagram for alternator hookup
    Hope this helps... you have the wrong schematic...........
  3. #3
    Join Date
    Aug 2008
    Location
    Charlotte, nc,
    Posts
    82
    Thanks that was the ticket. One more question. I have flat tappet lifters can I do the breakin procedure OJ garden hose? I have very strong water pressure.
  4. #4
    Join Date
    Jul 2008
    Location
    Northboro, Ma, USA
    Posts
    4,788
    Yes,
    It is safe to run a boat on a garden hose but keep it under 3000 rpms.............
  5. #5
    Join Date
    Feb 2009
    Location
    camborne, cornwall, uk
    Posts
    68
    hi guys i have the same problem or similar i took the starter out and forgot to lable the wires , the engine is a 5.0 1998
    the engine starts fine then dies because of fuel starvation , i have checked the fuel pump and it runs while cranking but as soon as the engine is running there is no power to the pump
    so question is ther are four pins on the starter which wire goes where , have a yel/red , pur/yel , orange , red im ok with the red and orange i think
    thanks
  6. #6
    Join Date
    Feb 2009
    Location
    Posts
    68
    hi guys i have the same problem or similar i took the starter out and forgot to lable the wires , the engine is a 5.0 1998 <BR>the engine starts fine then dies because of fuel starvation , i have checked the fuel pump and it runs while cranking but as soon as the engine is running there is no power to the pump <BR>so question is ther are four pins on the starter which wire goes where , have a yel/red , pur/yel , orange , red im ok with the red and orange i think<BR>thanks
  7. #7
    Join Date
    Aug 2008
    Location
    Charlotte, nc,
    Posts
    82
    Quote Originally Posted by kghost View Post
    Yes,
    well, i tried and tried to start the motor. but to no avail. I had the number one lined up perfectly and nothing. I then advanced the dist a bit at a time. I did get a backfire pop. But just cant get it to keep ticking. anything I should look for other than the wiring to the dist??? p.s. everything on this motor is brand new. with the exception of the wiring harness. should i start a new thread?
Similar Threads
  1. Old alternator and no wire diagram
    By briang0 in forum Crusader Marine Engine Forum
    Last Post: 06-06-2011, 02:20 PM
  2. Mercruiser 470 Wiring Diagram
    By geoffrixon in forum Mercruiser Sterndrive Archive
    Last Post: 04-29-2009, 08:28 PM
  3. Mercruiser wiring diagram
    By cruisers00 in forum Crusader Marine Archive
    Last Post: 02-24-2009, 10:22 PM
  4. 43gl volvopenta alternator hookup
    By Alben in forum Mercruiser Sterndrive Archive
    Last Post: 10-03-2006, 08:44 PM
  5. Mando alternator hookup
    By tnduke in forum Mercruiser Sterndrive Archive
    Last Post: 06-26-2006, 11:24 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
