Results 1 to 7 of 7
  1. #1
    Default Identifying OMC remote throttle
    I have an 18' Lowe jon boat w/ a 1991 40 hp Johnson. The trim switch has went bad on the remote sidemount throttle, and I am trying to find out what year model it is. I am not sure if it is a 91 or older. Is there any way to identify the year model of the remote throttle.
    The only numbers I could find are on the inside of the throttle housing and they are 334764. Any info would be appreciated.
  2. #2
    Join Date
    Apr 2008
    Location
    San Jose, CA, USA
    Posts
    210
    Default Re: Identifying OMC remote throttle
    Not sure what you are looking for. If you already know your motor is a '91. You just need to get a trim switch in a large range of years to work with your control box. Anything from '89 thru '95 will work (I believe)
  3. #3
    Thanks qhn, I am pretty sure it is a 1991 and I will check the part #'s to make sure. The problem I'm having now, is I cannot get the actual throttle handle that houses the trim switch apart from the body. I have the body seperated, but cant get the handle off.
  4. #4
    Join Date
    Apr 2006
    Location
    , Langkawi, Malaysia
    Posts
    5,750
    Put the throttle complete at your lap with the handle down.
    Un-screw the screw at the back a couple of turns, then give it a HARD knock using a hammer.
    The handle should come loose -remove the screw and handle.
  5. #5
    Join Date
    Jul 2011
    Posts
    81
  6. #6
    Join Date
    Jun 2010
    Location
    Milton, Fl
    Posts
    546
    here is the link for the side mount remote with the T & T switch.
    http://www.marineengine.com/parts/jo...Remote+Control
    BRP is no longer making the part, that is why it now list for $100.00.
  7. #7
    Thanks guys for your research and help. HollinKY
Similar Threads
  1. Remote throttle linkage questions
    By cool_ways in forum Volvo Penta Gas Archive
    Last Post: 07-12-2009, 09:31 PM
  2. Remote and throttle cable
    By bob68vw in forum OMC Sterndrive and Inboard Archive
    Last Post: 03-23-2009, 12:13 AM
  3. Remote Throttle 1990 8hp Evinrude
    By SoCal Matt in forum Johnson Evinrude Outboard Archive
    Last Post: 07-31-2008, 03:53 AM
  4. Old outboard remote throttle control failed
    By jasno999 in forum Johnson Evinrude Outboard Archive
    Last Post: 06-12-2008, 10:16 AM
  5. Throttle Remote Problems
    By bthornhill in forum Mercury Mariner Outboard Archive
    Last Post: 03-30-2007, 06:40 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
