Hi
Having redone the timing earlier this week (and got some extra power - 2 teeth out or so) on an AQ151A, I noticed the coolant was leaking into the bay down by the oil filter area (oil is nice and clean). Just to get it right in my head before I go back and try and fix it - the coolant leaves the heat exchanger via the thermostat, into the head / block - exits back to the bottom of the exchanger via the rubber hose. I noticed the drips coming from around the oil filter / 2 and 3 cylinders - could it be one of the push caps on the block has cracked causing the leak ? The raw water does not go via the block, only via the heat exchanger, oil cooler and exhaust manifold.
Cheers
Stu
Cheers
Stu
