boat 1963 comet 14"
engine 1975 70hp Chrysler
prop 13x21
trim tilt single cylinder 1991 70hp force
problem is trim/tilt does not work at WOT when engine is trimmed fully down. No leak down, no bleeding.
T
rim/tilt works when not moving and works when i slow down the boat to 30mph after that the trim tilt works great at all speeds
pump motor failing???
its like the pump isn't strong enough to lift the motor at wot but can do it a half speed and then has not problem after the initial lift to work properly
prop 13x21
T
