Thanks. My current switch does have an accessory position, which I use when doing things such as lowering the outdrive and checking how much gas is in the tank. Using the simple switch above, how would you do those things without fear of damaging my ignition system because I forgot to turn the key to OFF?
Well, with all respect to you, allow me to punch some holes in that (friendly comments) and allow me to make a few suggestions for the sake of the conversation here!
My thoughts are, that with any O/B 12 vdc system, it requires that we be vigilant with regard to Battery Management.
Ideally we're set up with an MBSS (main battery selector switch)... or two MBSS's if we have twin engines.
This allows us to select which bank we'll be using.
When we are on board and planing to go out.... the MBSS is set to the bank we intend to use.
Accessory circuits are generally supplied outside of any Ignition Key switch source.... at least in my world.
This may include the Trim or Tilt Out system, GPS, VHF, AM/AF Radio, Nav Lights, Anchor Lights, etc.
Meaning that these are independant of any Ignition switch source and/or position.
Many of these items do not actually require ON/OFF key switch operation.
In fact, I prefer to have my GPS, VHF, radio, etc, powered outside of any Key operation......, and then power-down when I choose to.
As for not remembering to turn the key switch back to OFF position..... I think that it's equally important to return to OFF position
from either ACC or Ign.
Granted, we do not want to continue powering an ignition system when the engine(s) are not running.
So I agreee with you on that.
Here's are a few suggestions:
Install an LED at the helm indicating when the Key Switch is "ON" Acc mode..... could be green/could be red.
Install an LED at the helm indicating when the Key Switch is "ON" Ign mode.
Install a green LED in your Main 12 vdc breaker panel.
When the MBSS is "ON"..... the Green LED is lit.
My main 12 vdc panel is set up like this..... and it does help me to see that my 12 vdc power is on or off.
If you want to get more complex regarding the Key Switch on/off......, you could install an alarm that sounds when Ignition is ON.
A NC oil pressure switch can pull this out of the loop once the engine starts.
Rather anoying.... but many of the newer engine packages are set like this.
Anyway.... just offering a few suggestions.
