Click for Volvo Penta parts and manuals!
Results 1 to 4 of 4
  1. #1
    Join Date
    Jul 2011
    Location
    Pueblo Colorado
    Posts
    8
    Default volvo penta aq130 water pump seal impeller question
    New to the boat world Have done alot of work on my boat.. I got water in my oil and it seems the culprit is the water pump seals.. Today I ordered a new impeller kit. Has new impeller, gaskets,oring, and 2 seals.. So my question is is there any kind of lube thats supposed to be on the seals?? I have built many cars and transmissions ect.. what and is there supposed to be lube on these seals on install?? I did notice the old seals were dry.. The impeller shaft has a cut around it.. Im going to smooth it up with some 600 grit sandpaper.. Any Help or in put would be great!!!
  2. #2
    Join Date
    May 2010
    Location
    Sebastian ,Fl
    Posts
    2,464
    Default Re: volvo penta aq130 water pump seal impeller question
    Yes lube the seals in you want.
    The shaft:how deep is the cut?Too deep and it will suck air making the pump useless.
    Assemble it and try blowing thru it as you turn it.ANY air and the shaft should be replaced.
    What shape is the cover and inside of the pump? Deep grooves(no good).The eccentric cam can be replaced too.
    Post some close up pics.J
    88 Bayliner with 2002 225 HP Mercury EFI
    Buy American made Cars and Trucks!!!Towing insurance for a boat,a GREAT thing.
    ​Tools to make my life easier: Battery tester, die grinder, temp.gun, compression tester, DVA meter.
    In Scenic , Beautiful San Sebastian by the sea Florida
  3. #3
    Join Date
    Jul 2011
    Location
    Pueblo Colorado
    Posts
    8
    i will get some pics when i can busy time of year for work wise.. sucks no time for boat.. but the cover i think can be sanded down with fine grit same with the shaft. but it does have one cut in it pretty deep wont sand out.. the cam is smooth..
  4. #4
    Join Date
    May 2010
    Location
    Sebastian ,Fl
    Posts
    2,464
    The cam would be smooth.It wears down and looses shape.If the shaft has deep cuts(to save $) it can be filled with liquid metal and worked down.
Similar Threads
  1. Impeller & water pump question 1990 15 hp
    By shimanok2 in forum Johnson Evinrude Outboard Forum
    Last Post: 04-12-2011, 09:45 PM
  2. Volvo Penta 5O GL water pump
    By jerryl in forum Volvo Penta Gas Engine Forum
    Last Post: 09-28-2009, 05:55 AM
  3. Water pump 74 GL DP volvo penta
    By goco in forum Volvo Penta Diesel Archive 2004-2009
    Last Post: 10-02-2008, 07:38 AM
  4. Volvo Penta Marine AQ130 differences
    By Jeremy Poole in forum Volvo Penta Gas Archive
    Last Post: 05-17-2008, 09:00 PM
  5. Volvo Penta 2002 Water Pump Question
    By bowringi in forum Volvo Penta Diesel Archive 2004-2009
    Last Post: 04-18-2008, 05:03 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
