Click for Bukh manuals!
Results 1 to 2 of 2
  1. #1
    Default DV8 SME Charging Problem
    i have replaced alternator, regulator and diode boaboard (new components) but still system only charging at 12.6v flat out at full revs. any suggestions greatly appreciated [email protected]
  2. #2
    Join Date
    Aug 2009
    Location
    Hobart, Tasmania, Australia
    Posts
    114
    Default Re: DV8 SME Charging Problem
    G' day Simon,
    Are you measuring voltage at alternator or at end of wiring run at dash board?What are you using to record voltage analoge gauge or a digital multimeter,does the system have a field switch fitted if so remove & retest.
    Cheers, Shakey.
Similar Threads
  1. new guy here with a charging problem
    By ttcfan4476 in forum Johnson Evinrude Outboard Forum
    Last Post: 06-27-2011, 10:12 PM
  2. Charging problem
    By Thanks in forum Johnson Evinrude Outboard Archive
    Last Post: 05-28-2008, 04:55 PM
  3. Charging problem
    By nocharge in forum Mercruiser Sterndrive Archive
    Last Post: 08-15-2007, 01:00 PM
  4. Charging problem
    By Randy Achor in forum Mercury Mariner Outboard Archive
    Last Post: 01-17-2007, 01:08 AM
  5. Charging problem
    By dct2 in forum Archive 2003-2007
    Last Post: 07-22-2003, 09:59 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
