2001 Indmar LTR 330hp
mcrowe
Hey everyone, new to these forums.
I have an 01' Mastercraft x30 with the Indmar LTR engine. I am getting a check engine light intermittently only at low rpm. Once I get above about 1500rpm the light goes away. Does anyone have any idea what this could be?
Just in case anyone cares.... It ended up being debris in the cooling system. It was allowing plenty of water through, but letting the temp rise about 7 degrees which was enough to intermittently set off the CEL....after clearing out some rubber (old impeller) and some seaweed the CEL is gone! Who knows, maybe someone else will have the same issue. It was odd.....the CEL was one but it did not throw any codes.
