Get instant online access to repair manuals for your Chrysler / Force outboard. Online Manuals
ChryslerForce
Order printed Chrysler / Force service manuals — shipped to your door! Printed Manuals
ChryslerForce
Use engine diagrams to find & order parts for your Chrysler / Force engine. Engine Diagrams
ChryslerForce
Results 1 to 2 of 2
  1. #1
    Join Date
    Jul 2007
    Location
    westhampton beach, ny,
    Posts
    53
    Default motor dies at idle when hot
    I have an 1989 85 hp force, starts fine, runs great at wot, but when dropping back to idle she stalls out and very hard to start. once restarted will not idle. I adjusted carbs and timing to no avail. Any help would be greatly appreciated.
    Mauro
  2. #2
    Join Date
    May 2010
    Location
    Sebastian ,Fl
    Posts
    2,414
    Default Re: motor dies at idle when hot
    First reset the timing to specs.No such thing as setting it by ear/touch or the wag system(wild a%# guess).Get a manual.
    You mess with the air screw? Turn screw in till it just bottoms(gently) then out 1 and 1/16th turn.
    The idle should be 750-800 in gear and warm.
    Idle adjustment is with the towershaft.No other way.
    Check the pump diapham.The float levels.Check for water in the gas.
    Do a compression/spark test.
    How old is the waterpump? It might not be keeping it cool enough?J
    88 Bayliner with 2002 225 HP Mercury EFI
    Buy American made Cars and Trucks!!!Towing insurance for a boat,a GREAT thing.
    ​Tools to make my life easier: Battery tester, die grinder, temp.gun, compression tester, DVA meter.
    In Scenic , Beautiful San Sebastian by the sea Florida
Similar Threads
  1. 7.5 dies at idle
    By stoo in forum Honda Outboard Forum
    Last Post: 09-30-2010, 08:15 PM
  2. 1990 Force 90 idle problem Motor dies in gear PLEASE HELP
    By beemerjunkiesbcglobalnet in forum Chrysler Force Outboard Forum
    Last Post: 11-18-2008, 03:04 PM
  3. Dies at idle
    By kevgrn114 in forum Mercruiser Sterndrive Archive
    Last Post: 07-09-2008, 04:36 AM
  4. 1974 evinrude 25hp hard start rough idle dies at low idle
    By mike gray in forum Johnson Evinrude Outboard Archive
    Last Post: 05-16-2006, 04:56 PM
  5. 70 johnson idle very rough dies when at low idle
    By tcalhoun in forum Johnson Evinrude Outboard Archive
    Last Post: 08-04-2003, 08:50 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
