Results 1 to 2 of 2
  1. #1
    Default 90hp johnson 2stroke 2000 outboard
    where is the idle adjustment for the johnson 90hp 2stroke ?
  2. #2
    Join Date
    Apr 2006
    Location
    , Langkawi, Malaysia
    Posts
    5,750
    Default Re: 90hp johnson 2stroke 2000 outboard
    If a 60 degree looper (OIS), use the ignition adjustment on top of the flywheel cover.
    Move the tab marked 'Low' either towards + to increase or - to reduce idle.
Similar Threads
  1. 2001 Johnson 50hp 2stroke outboard....what mixture??
    By dimebag88 in forum Johnson Evinrude Outboard Forum
    Last Post: 04-04-2011, 11:35 PM
  2. 2000 90 hp 2stroke Johnson
    By papasteele in forum Johnson Evinrude Outboard Archive
    Last Post: 05-04-2009, 01:04 AM
  3. Water coming out of drive shaft tube 2000 johnson outboard 90hp
    By ems in forum Johnson Evinrude Outboard Archive
    Last Post: 03-06-2008, 09:45 AM
  4. 93 Johnson 90hp 2stroke Extra hp
    By gjack in forum Johnson Evinrude Outboard Archive
    Last Post: 03-05-2008, 08:26 AM
  5. 2000 90hp johnson
    By rdc in forum Outboard motors archive 2000-2004
    Last Post: 08-05-2002, 04:38 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
