Results 1 to 3 of 3
  1. #1
    Join Date
    Jun 2011
    Location
    Alaska
    Posts
    3
    Default Question: water inlet hose
    Need a question answered I have to replace the water inlet hose. Do I have too remove the transom in order too replace it. It's on a 92 alpha 1 .. Plus how many hours does it take to do it?
  2. #2
    Join Date
    Dec 2006
    Location
    Chaumont Bay, N.y., USA
    Posts
    5,238
    Default Re: Question: water inlet hose
    Ayuh,... The "water inlet hose" from the drive to the transom is under the gimbel housing, which needs to come off...
    The "water inlet hose" from the transom to the T-stat housing is all done inside the boat...
    Why are ya changin' it,..??
    If the 1 outside the boat is rotten, 'n leakin',...
    The rest of the bellows, 'n the shift cable aren't far behind it in Failing...
  3. #3
    Join Date
    Jun 2011
    Location
    Alaska
    Posts
    3
    Well we took it in too just have the gimbal bearing replaced and the seen that the hose was cracking.. So we had it replaced said they had to remove the transom too put the hose back in.. Said it took 4 hrs to do..
Similar Threads
  1. Water inlet hose on 92 alpha 1
    By Ronnie73 in forum Mercury Mariner Outboard Forum
    Last Post: 06-28-2011, 07:06 PM
  2. water inlet connection
    By myquest in forum Volvo Penta Gas Engine Forum
    Last Post: 08-05-2010, 10:46 AM
  3. water inlet hose
    By Blunight77 in forum Mercruiser Sterndrive Forum
    Last Post: 06-13-2010, 11:12 AM
  4. Kink in water inlet in foot
    By atilla_boy in forum Mercruiser Sterndrive Archive
    Last Post: 01-29-2008, 07:33 PM
  5. Honda 10 HP 100 Thermostat Water Inlet
    By tbertw in forum Honda Outboard Archive
    Last Post: 09-29-2007, 01:25 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
