goosemanhnt4fud
Hello everyone,
Newbie here...
Newbie here...
Yesterday morning I took the boat out and it ran fine. Yesterday afternoon I took it out again, and it would not start. Today I tried to trouble shoot it. This is what I did:
1. Fuel pump is working, removed the line from pump to carbs,(carbs were cleaned two weeks ago) and it is squirting out gas.
2. Compression check is 146/146/147
3. I removed the spark plugs, and they were dry. I squirted some fuel in the #1 and #2 cylinders and tried to start it, but it would not fire.
4. I made sure the kill switch was in the run position.
5. The inline fuse on the hot wire that goes to the rectifier, fuse is good, and as I attempt to start the yellow wire that goes to the stator has power. (the stator does have some dry rotted wires)
6. all three spark plugs are new
7. Took a spark plug out, and turned over the motor and saw no spark.
What is my next step? Is there anything else I should look for, i'm pretty mechanically inclined...just looking for some light at the end of the tunnel...
Thanks in advance for all the help.
