Results 1 to 6 of 6
  1. #1
    Default johnson 9.9 fuel ratio
    i have an older 9.9 just not sure what the mix ratio is supposed to be
  2. #2
    Join Date
    Jun 2011
    Location
    SA Tx
    Posts
    242
    Default Re: johnson 9.9 fuel ratio
    50;1 fuel ratio buddy!!!if its a two stroke?
  3. #3
    thanks appreciate the info
  4. #4
    can I run a 100:1 ratio in a 9.9 Johnson? The reason is my main motor has oil injection and don't want to bring a second fuel tank. so add 50% to the main tank and run a little rich in the main motor and 100:1 ratio in the 9.9 any comments?
  5. #5
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    14,945
    ??------50:1 is a 2% mix.----------And no a Johnson should not be run on 100:1 mixture.
  6. #6
    Thank you Racerone
Similar Threads
  1. Fuel mix ratio for Johnson motors
    By tripnick in forum Johnson Evinrude Outboard Archive
    Last Post: 08-03-2009, 12:25 AM
  2. 40hp johnson mix ratio for fuel
    By earl in forum Johnson Evinrude Outboard Archive
    Last Post: 06-12-2009, 06:06 AM
  3. Johnson 50 HP Fuel Ratio
    By troy_d in forum Johnson Evinrude Outboard Archive
    Last Post: 05-14-2007, 10:03 PM
  4. What is the fuel mix ratio for a Johnson CJ15RCOB
    By Bob Purvis in forum Johnson Evinrude Outboard Archive
    Last Post: 04-24-2007, 07:00 PM
  5. Fuel Ratio for 86 Johnson 15
    By Randy Aiken in forum Johnson Evinrude Outboard Archive
    Last Post: 12-08-2006, 09:00 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
