So here's what I have going on and I would really appreciate some advice! The motor is overheating. Took it out on the water and had a mist from the tell tale thought I was good to go... took it up river a bit and only hot steam from the exhaust holes and BUZZZZZZ!!!! Brought it home and pulled the plugs, do not see any water so hoping the head is ok. Pulled the lower unit off and removed the thermostat. Everything looks just like it did the day i installed it. Took the water hose and forced water through the cooling tube and came out of the thermostat fine. So I am assuming that means there is no blockage in the cooling system. Could I be wrong? I have considered taking off the exhaust port plate and checking for clogs, debris, sand, etc. however I cannot get it off. The screws are too long and I cannot get the powerhead off. Does any one know how to do this? To me it just sounds like the pump is still not working. What do I do? Please help!!!
