MarineEngine.com - Your online store for all types of marine engines and boat parts.
PHONE ORDERS
Monday - Friday
9:00 AM - 5:00 PM EST
Click for TOLL-FREE Number
Secure Online Payments
Special $9.95 Flat Rate Shipping
(800) 209-9624 | Home | Contact | Shipping | Returns | Cart View your shopping cart.
Search by Part Number
Enter engine/drive part number.
Original & matching parts for sale.
Manuals & Accessories
Shop by description, item number
or manufacturer's model number.
Why shop with us? Check our reviews! Why Us & Reviews   Boat Repair Forum Boat Repair Forum   Boat Video Gallery Video Gallery
Results 1 to 5 of 5
  1. #1
    Default Yamaha 5hp 2-stroke water cooling problem
    Help! I suspect my impeller has gone but cannot get the lower housing off. Do I need to remove whole prop shaft housing at gear lever end?
  2. #2
    Join Date
    Jun 2011
    Location
    SA Tx
    Posts
    242
    Default Re: Yamaha 5hp 2-stroke water cooling problem
    from gear housing up about half way you should see the bolts where it comes apart.Buy a manual for that engine is the best thing to do.
  3. #3
    Join Date
    May 2008
    Location
    australia
    Posts
    295
    Dont pull out that propshaft housing just to do a water pump.
    Remove the screws holding the lower unit, and you should also see a round rubber cap on the exhaust housing above the lower unit.
    Remove the cap and disconnect the shift shaft from there... The lower unit should then come off...
  4. #4
    Thumbs up Re: Yamaha 5hp 2-stroke water cooling problem
    Thanks Ciscokid and Tonyaus, took it to local marine expert as no immediate replies to my enquiry here.
    Impeller is ok, but water cooling channels in head were clogged with salt,etc. Found pinch bolt as you said - under round rubber plug halfway up casing.
    Thanks again both.
    Regards,
    CornwallKen
  5. #5
    Join Date
    Jun 2011
    Location
    SA Tx
    Posts
    242
    Your welcome.Im glad you got it running!!
Similar Threads
  1. 2002 115 Yamaha 4 Stroke Water Pump Problem
    By boatbroke14 in forum Yamaha Outboard Forum
    Last Post: 04-09-2011, 06:16 PM
  2. Yamaha 115 V4 cooling problem
    By jarotom in forum Yamaha Outboard Forum
    Last Post: 08-14-2009, 07:32 AM
  3. 6HP 2 cycle Yamaha Cooling Problem
    By petewsp in forum Yamaha Outboard Archive
    Last Post: 02-07-2009, 08:32 PM
  4. 1993 90 hp 2 stroke cooling problem
    By Ralph Fraser in forum Yamaha Outboard Archive
    Last Post: 10-13-2008, 09:21 AM
  5. Cooling water flow Where does it go Yamaha 15hp
    By Smiffy in forum Outboard motors archive 2000-2004
    Last Post: 07-25-2002, 08:10 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
