" This is what happened. I was
" This is what happened. I was running back to the boat launch at about 50rpm then all of a sudden the motor bogged down to 1.5rpm, i got the boat home and checked the fire to the plugs , the top plug had fire the bottom had none,, i changed the bottom plug and got fire to it,, i then put the motor on the water hose and it seemed to run fine, but i know those things are only good for flushing out your motor and such minor things. so i took it back out to the lake and it still wouldnt get past 2rpm`s. Any suggestions?
P.S. i would also like to get the compression numbers ,..
Thanx: Travis "
Thanx: Travis "
