Results 1 to 5 of 5
Thread: Tomos 4hp
  1. #1
    Default Tomos 4hp
    Hi
    Can someone please help me with description/photos?
    I have a Tomos 4hp air cooled and i removed the small infill plate at the front where the stop buttong is and off popped two white wires. One comes from the back of the stop button and has an eylet crimp on the loose end and the other loose wire comes from a plastic connector block under the carb and is also white. As i didnt see where the wires were connected before they popped off i dont know where to re-connect them. can someone please guide me so that i can run my engine again?
    Also i had been running my engine on a 4% 25:1 mix of dedicated twc3 outboard 2 cycle as the manual i have mentions 25:1 but i believe i should be using 50:1 in this dedicated oil as i have checked the plug and it is blackened, am i correct?
    Finally when i squeze my priming bulb i can get fuel leak out of the brass screw/plug at the rear of the carb next to the engine, it has no head on it so i dont know if it is screwed or pressed in but it will leak fuel if i squeeze the priming bulb???
    Thanks in advance for your help
    Svdsniper
  2. #2
    Join Date
    Oct 2008
    Location
    , hertfordshire, uk
    Posts
    32
    Default Re: Tomos 4hp
    If I remember right 50:1 was for running in and 100:1 after that, but I would stick to 50:1.
    Also two types of carb's on the Tomos4, would need more info, as I do have manuals.
  3. #3
    Quote Originally Posted by seagullkeith View Post
    Hello would you mind emailing a copy of those manuals i would greatly appreciate it! I have been searching for the 4hp manuals for a long time! thanks
  4. #4
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    3,845
    Quote Originally Posted by danp View Post
    This thread is over six years old!
    It takes a nickle to go first class!
    If it aint broke dont fix it!!
  5. #5
    Quote Originally Posted by kimcrwbr1 View Post
    Well it was worth a try. Still doesn't change the fact that i need these manuals and maybe the op might have still had those manuals. Thats why i tired.
Similar Threads
  1. Tomos 18HP
    By Ricardo Page in forum Tomos Outboards
    Last Post: 02-27-2016, 06:46 AM
  2. Tomos 5 HP
    By springbok74 in forum Tomos Outboards
    Last Post: 11-24-2012, 02:29 PM
  3. Tomos
    By xrs080 in forum Tomos Outboards
    Last Post: 09-17-2008, 05:23 AM
  4. Tomos 4hp won%60t start
    By winrace12 in forum Tomos Outboards
    Last Post: 09-02-2007, 11:49 PM
  5. Tomos Outboard
    By ttucker in forum Tomos Outboards
    Last Post: 08-04-2006, 12:04 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
