My starter motor Bendix Drive does not engage with flywheel ring gear. When I turn engine keyswitch to start, starter motor turns but Bendix does not throw out to engage flywheel.
Could this be caused by weak battery? I plan to put 2 new batteries in this week based on age, but current batteries are on shore power charger and show charge ready.
My manual does not get into mechanical troubleshooting of starter Bendix. Yes, battery cables are tight.
I pulled starter and took apart to clean forward section of shaft where Bendix should ride when in engagment thinking that residual surface rust may be hanging it up. Same result when put back together. Entire internal parts of starter are clean and shiney as if new. It has never been under water and worked fine last time out on 06/06 when fishing with many starts thoughout the day.
Suggestions? New batteries go in Thursday. Also, manual does not make recomendation of battery size for M440. Any suggestions?
Thanks, Noel.
Thanks, Noel.
