Results 1 to 4 of 4
Thread: Fuel
    Jun 2011
    Garner North Carolina
    8
    Default Fuel
    Can you convert the old style 2 line tank system to the new style on the 1955-1957 johnson outboard motors? Thanks Tom
    Sep 2010
    19,066
    Default Re: Fuel
    There is nothing wrong with the concept of the 2 line pressurized gas tank.-------------If you insist on changing over then there is lots and lots of info on it.--Just visit the AOMCI and post there.
    Jun 2011
    8
    Default Re: Fuel
    Thanks, the only reason I ask is because I'm having a hard time finding the old style tank at least any that are worth anything.
    May 2009
    Marine Engine
    563
    Default Re: Fuel
    Hello Smilington,
    here is also a good article Click Here
  1. fuel filter/water separator fo premixed fuel 85hp
    By bredfan in forum Johnson Evinrude Outboard Forum
    Last Post: 09-02-2010, 03:23 PM
  2. Starving for fuel anti syphon valve or fuel pump
    By stigmen in forum Mercruiser Sterndrive Archive
    Last Post: 06-28-2007, 03:05 PM
  3. Plastic fuel tank rubber fuel lines amp grounding
    By cwebb in forum Archive 2003-2007
    Last Post: 12-02-2006, 11:50 PM
  4. Fuel water separator or just fuel line with filter on AQ125B
    By Javier Cubero in forum Volvo Penta Gas Archive
    Last Post: 10-17-2006, 07:39 PM
  5. Replies: 3
    Last Post: 05-21-2002, 02:00 PM
