Click for Honda Manuals, Parts and Model Guides!
Results 1 to 3 of 3
  1. #1
    Join Date
    Jun 2011
    Location
    South Texas
    Posts
    2
    Smile Fuel Pump for BF115
    Did Honda re-design their fuel pump assembly? I have a 2000 bf115 and the site I am looking at says the part is obsolete, but does have another part number to order. Thanks in advance.
  2. #2
    Join Date
    Mar 2009
    Location
    Cincinnati, OH USA
    Posts
    4,236
    Default Re: Fuel Pump for BF115
    If you are talking about the high pressure fuel pump. If yours is located below your vapor separator like this one ,http://www.boats.net/parts/search/Ho...IPE/parts.html
    that whole assembly was supposed to be changed out years ago to a vapor separator with the high pressure fuel pump inside of it. The vapor separator, several hoses, water separator and fuel rail are all updated or added. The part number for the kit is 06167-ZW5-305. It runs about $380 retail.
    The old pump had failure problems especially if they got water in it.
    If it is the low pressure pump, there appear to be only 4 in stock in the country. I do not know of a substitute. If you are being told there is one, let us know what it is.
    Mike
  3. #3
    Join Date
    Jun 2011
    Location
    South Texas
    Posts
    2
    It is the vapor separator. Thank you for the information and quick reply. I did order the new separator and the boat is at the shop now. Thanks again.
    Randy
Similar Threads
  1. bf115 extension case
    By branda in forum Honda Outboard Forum
    Last Post: 02-17-2011, 12:36 AM
  2. BF115 impeller?
    By superstock426 in forum Honda Outboard Forum
    Last Post: 01-15-2011, 11:16 PM
  3. BF115 - Will not start
    By mfp in forum Honda Outboard Forum
    Last Post: 09-14-2010, 10:00 PM
  4. Replacing automotive fuel pump with marine type fuel pump on a 318 Chrysler
    By eetgar in forum Chrysler Inboard and Sterndrive Forum
    Last Post: 07-13-2010, 08:09 AM
  5. New 04 BF115 wonbt start
    By scottymac2345 in forum Honda Outboard Archive
    Last Post: 07-15-2008, 06:52 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
