Hello, I am new here and have a question about my motor maybe some one could help. Okay I just picked up this boat ,I had to replace the harness, battery and battery cables do to some one at midnite auto sales. After that repair I was trying to start it and noticed that a very lot of fuel spilling out from the carb I found some where on one of the forums how to adjust the carb. Well I put it in the lake ran like crap sputtering and stalling (flooding out)with no power. I got home checked the point's cleaned and re-gaped ,re-gaped plugs, took off the carb and cleaned and adjusted the float, that is I flipped the carb over and looking at float made it so it was sitting just above level.re-adjusted high ,low mixture again. Took it out on the lake again started right up ran great . I then tried to adjust the carb in 1/8 turn in. Then the engine started surging no power sputtering all most like some one turning key on and off. Could it be a bad coil or fuel pump or maybe the points out of gap again . I am at whits end, maybe I did some thing or not ,hopefully some one else can point out to me .
