MarineEngine.com - Your online store for all types of marine engines and boat parts.
Order by phone
(800) 209-9624
Monday - Friday
8:30 AM - 5:30 PM EST
Safe Online Orders
Comodo Enhanced Security
Special $9.95 Flat Rate Shipping
Boat Repair Forum Boat Repair Forum     Boat Video Gallery Video Gallery
Home | Contact | Shipping | Returns | Cart View your shopping cart.
Part Number Search
Shop by engine/drive part number.
Original & matching parts for sale.
Manuals & Accessories
Shop by description, item number
or manufacturer's model number.
Click for Nissan Tohatsu Manuals, and Parts!
Results 1 to 5 of 5
  1. #1
    Join Date
    Aug 2008
    Location
    Freeport, Pa, USA
    Posts
    45
    Default Starting a flooded engine.
    RE:MFS9.8A3S.Any way to start this engine after i flood it.If i let it sit for at least 30 mins.it will usually
    start,but not always.
  2. #2
    Join Date
    Mar 2010
    Location
    Buffalo, NY, USA
    Posts
    1,036
    Default Re: Starting a flooded engine.
    The only 2 ways that you would flood the fuel system would be if you had the choke on when unneeded, or if the carb needle and float assembly is not limiting the fuel at the correct level in the bowl. If the former, stop choking when not needed. If the latter, have the carb serviced by your dealer (or get a kit and do the service yourself). To restart when flooded, open the throttle all the way (with no choke), to admit as much air as possible, and crank the motor until the excess fuel is expelled. If the plugs are soaking wet, you can dry them first (with compressed air, or laid out in the hot sun), to aid starting.
    Paul
    Certified TLDI Technician
    Buffalo NY USA
  3. #3
    Join Date
    Aug 2008
    Location
    Freeport, Pa, USA
    Posts
    45
    This only happens at the initial start up for the day and not very often.Is it possible to over prime this engine?It seems to happen when i am in a hurry to get going and not minding what i am doing.I also run the carb dry at the end of the day.Would it be of any benefit to pull the drain plug on the carb to expell the remaining fuel?
    Thanks for the help.
  4. #4
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    7,430
    Some motors will fire up / start with the choke closed and then stall ( flooded with too much fuel ).----------------The choke has done its job and now you open the choke.------- Pull a few more times and it it should fire up and keep running.
  5. #5
    Join Date
    Mar 2010
    Location
    Buffalo, NY, USA
    Posts
    1,036
    Quote Originally Posted by jaseihc View Post
    No. But if the needle is not seating, you could be overflowing with fuel. If so, you would probably notice that.
    No; not necessary to get the last teaspoon out.
    See my earlier post.
    Paul
    Buffalo NY USA
Similar Threads
  1. Engine flooded with water 1978 140a
    By dusher in forum Volvo Penta Gas Engine Forum
    Last Post: 03-09-2010, 08:39 PM
  2. Possibly flooded
    By mschwenz in forum Mercruiser Sterndrive Archive
    Last Post: 08-31-2009, 09:44 AM
  3. Flooded 43 merc
    By lineman in forum Mercruiser Sterndrive Archive
    Last Post: 06-06-2009, 08:30 PM
  4. Locked and flooded
    By TJW in forum Archive 2003-2009
    Last Post: 08-14-2003, 04:38 PM
  5. Flooded 318 crys
    By Tog Boat in forum Archive 2003-2009
    Last Post: 04-16-2003, 07:56 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
