Hi kghost,
I know this thread is old but I am new to ALL boating stuff and find myself laying awake at night working about this cable route, following the removal and self rebuild of my Bayliner Ciera 2155 Sunbridge 5.0L GM engine coupled to an OMC outdrive. I really do hope you are still active and can help me.
The issue for me is the importance of the single pipe clamp on the transom for the outer sheath that the shift cable runs through as it seems so fragile a connection when you think it is below the water line and easily dislodged. I have reinstalled the engine and didn't take note of the run of this over pipe on dismantle.
My shift cable works nice and freely and shifts freely but there is no movement through the over pipe so the outdrive will not push back enough to refit to the Pivot Housing to the Grimble Ring without bending the shift cable.
What I think I have done - whilst I have the correct route around the power steering and onto the shift assist mechanism on the top of the engine, I think I haven't followed the exact route from the transom. Mine is "over the exhaust pipe, then it looks pinched down by the flywheel housing and then bends starboard". I think what you are advising is " from the transom over the exhaust and immediately bend to starboard through a small gap between the engine mount and flywheel housing, then around under the exhaust and up behind the power steering unit and on to the shift mech"?!
If you confirm this is how it should be I will have to re-hoist the engine and check the Jubilee pipe clamp is still holding the outer pipe in place and then route it correctly.
I do not want this thing sitting at the bottom of the murky river Stour.
