Results 1 to 5 of 5
  1. #1
    Default Mercruiser 5.0L Alpha One Circulating pump replacement
    I need to replace the circulating pump on my engine, I plan to do it while the boat is in the water, anyone see any problem?
  2. #2
    Join Date
    Sep 2010
    Location
    Jersey Shore
    Posts
    4,757
    Default Re: Mercruiser 5.0L Alpha One Circulating pump replacement
    Changing the circ pump on the front of the engine is not a problem while the boat is in the water.
  3. #3
    Join Date
    Mar 2009
    Location
    Portland, Oregon,
    Posts
    9,484
    Closed Cooling System.... or Open System?
    If closed, you can use the automotive short body version, and save a few dollars.... the circ pump will not know that it's been installed on a marine engine.
    However, if "open", you'll want the Marine version.
    Rick ... aka Ricardo..... AQ series Volvo Penta repair
    Portland, Oregon
    28' SDN F/B w/ twin Volvo Penta 5.7L DP's
    Please... no PMs! Post your questions on the forum.
  4. #4
    Thank you very much for the quick response, I didn't think it would be a problem, being above the water line and no pressure.
    Thanks - Good Forum
  5. #5
    Join Date
    Jul 2010
    Location
    Canada
    Posts
    631
    For future refference, best to post in the Merc forum. Not all the Merc guys frequent the other engine forums. Although there is a Volvo guy that does!! LOL
Similar Threads
  1. Replacement circulating pump seals
    By basilforty in forum Volvo Penta Gas Engine Forum
    Last Post: 11-13-2010, 05:10 AM
  2. Know the water circulating pump replacement auto equivelent?
    By 1stboat in forum Volvo Penta Gas Engine Forum
    Last Post: 07-06-2010, 09:48 PM
  3. Circulating pump replacement
    By Srgentpepr in forum Volvo Penta Gas Engine Forum
    Last Post: 05-04-2010, 01:46 PM
  4. Mercruiser outdrive alpha replacement Skeg
    By burkstar in forum Mercruiser Sterndrive Archive
    Last Post: 05-16-2009, 04:39 PM
  5. Perkins 4154 Coolant Circulating Pump Replacement
    By Frank Coviello in forum Perkins
    Last Post: 07-17-2007, 06:12 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
