I have a 1975 35 ft Aft Cabin with Chris Craft 350 's (Chevy) engines. Replaced the Port Starter last winter. To me it sounds like you need to shim the starter. The starter gear needs a little clearance between it and the flywheel ringgear. With the engine in the boat its very hard to measure the clearance. If you hear the Flywheel "ring" after starting its a good indication that the starter needs more clearance. Hope I could help.Good Luck.I have a 1976 35 ft catalina. I have been having issues with the starter getting it's teeth chewed up. and the starter has been rebuilt and replaced several times over the past few years, and we even had the big fly wheel replace and yet it has occured again. Any ideas??
If these are being rebuit (as apposed to being replaced), they are likely the OEM Bendix Drive motors.I have a 1976 35 ft catalina. I have been having issues with the starter getting it's teeth chewed up. and the starter has been rebuilt and replaced several times over the past few years, and we even had the big fly wheel replace and yet it has occured again. Any ideas??
