Hi all, I was wondering if there's any members on here that are/ or know a mercury outboard mechanic that lives in the Hamilton area?
I've been having some issues with this motor since last year in a couple different areas and I think it's time that I finally bite the bullet and employ the hands of an expert. I'm about 99% positive that all it needs now is to be tuned. I've got it very close (I think) but from here it's a little out of my league.
Details:
1983 Mercury Thunderbolt 80hp
-Ran perfect when purchased beginning of last year, started acting up near the end of the season. No work done last year but fully winterized before being stored.
-New gas w/ ethanol treatment put in at beginning of this season
-Rebuilt both carbs and fuel pump including all new fuel lines
-new tank lines, bulb, connectors
I've got it to this point:
-Cold start: Prime bulb, crank w/ choke, fires and stalls, then crank w/ no choke, fires up
-Warm start: Starts immediately. Within two/three cranks
-Shift into gear: Shift into gear, motor stalls. Shift and give just enough throttle until throttle cable starts to move, motor sounds perfect and runs.
-Accelerating: In gear motor putts along great, 1/4 way through throttle range, motor has an instant of power loss then recovers and runs smooth and constant all the way through top end.
The only time it seems that I need to use the fast idle is after it stalls when shifting into gear and I try restarting it.
More details can be given as to what I've adjusted but it would take forever to type.
So is there anyone that could help me out? I'm hoping to get someone out on the water for a little troubleshooting. Hamilton Harbour.
By the way, I'm not a cheapskate. YOU WILL BE PAID!
P.s. Just incase assumptions are made, I do not have a tach on it for rpm reference.
Thanks guys.
Details:
Thanks guys.
