Results 1 to 8 of 8
    Default Trim Will Not Lower or Raise - only clicks pressing toggle up & trailer buttons
    Hello. I have a Mercruiser trim problem. Currently, it's stuck in the UP position. When I try to lower the trim by using the toggle down button, I only hear clicks. If I press the TRAILER button, I also hear clicks. When I press the trim UP toggle, I hear nothing. The does engine start.
    I have checked all the connections around the solenoids, cleaned them up, & replaced the UP solenoid b/c it was completely black.
    When testing the connections w/a voltage tester (which I'm not totally sure how to do): the only connection that I got a spark from was on the UP solenoid - and only on the smaller bolt to the top right, which holds a blue/white colored wire, which runs to the trim control wiring harness.
    I've also checked & filled the power trim pump oil.
    Please Help!
    Jun 2006
    Spotswood, NJ, USA
    4,439
    Default Re: Trim Will Not Lower or Raise - only clicks pressing toggle up & trailer buttons
    And the year of this trim pump?
    I'm not exactly sure if the trim pump has ever been replaced - it looks old (see picture). The boat is a 1987.[IMG][/IMG]
    The picture was taken before I cleaned all the connections.
    Jun 2006
    Spotswood, NJ, USA
    4,439
    From the motor :blue wire is up, green wire is down, black wire should go to the housing or to the same point that the main neg cable attaches. ,not the solenoid.
    using jumpers from the battery neg to black wire of motor, pos to blue,motor should run up, to green motor should run down.If it now runs, check that square block that has the pos cable. it`s a fuse link that may be corroded.
    http://www.boatfix.com/merc/Techbk/97/97hs6.pdf
  6. #6
    Jul 2010
    Canada
    631
    Follow BT's suggestion and report back. You don't hear anything with the trim UP toggle because you're at or passed trim limit (normal).
  7. #7
    mine is stuck n the up position and clicks both ways. Any Suggestions
  8. #8
    Jun 2006
    Spotswood, NJ, USA
    4,439
    use a jump wire from the + battery and touch the Green motor wire , motor should run. If not:
    check and clean main power connections both pos and neg
    using a jumper from the + battery, touch the green motor wire, motor should run ,if not disassemble and clean armature in motor and check brushes. In most cases motor replacement fixes the problem
  1. Suzuki DT 40 86 Power trim bleeds down when I raise it
    By louisianaxray in forum Suzuki Outboard Archive
    Last Post: 05-18-2009, 01:29 PM
  2. Trim only clicks
    By searay123 in forum Mercruiser Sterndrive Archive
    Last Post: 04-10-2008, 07:59 PM
  3. Tilt trim buttons
    By outdoorjoe2 in forum Mercury Mariner Outboard Archive
    Last Post: 08-01-2007, 03:06 PM
  4. Cannot raise lower end of Evinrude 48hp 1995
    By ED De in forum Johnson Evinrude Outboard Archive
    Last Post: 07-07-2006, 03:17 PM
  5. Motor wonbt raise on my power trim only lower
    By jeff schneidewend in forum Archive 2003-2009
    Last Post: 12-04-2003, 11:32 AM
