bill_w
Advanced Contributor
Okay, back to old Evinrudes. I bought a basket case 1958 5 1/2 Fisherman, it came in two milk crates, but I was told it did run. Well, I reassembled it enough to try it, and it did run, but badly. Okay, new coils, new points, new wires and plugs. Did a carb rebuild, cleaned the tank, new lines, new everything, tore the gear case apart, replaced gears and bearings and seals, new impeller.
Tried to fire it yesterday, after the new paint had dried enough to be handled. Long story short, nothing!!!!!! I set the timing with an ohmmeter, so I know thats ok. Great spark, jumps a 1/4 inch gap with a loud zap, on both wires. The carb is getting fuel, the float bowl and filter are full, and there is fuel in the carb throat. All I got out of about an hour of pulling was a couple of backfires from the carb. I even tried reversing the plug wires, thinking I might have switched them. That got me one backfire out of the exhaust. I sprayed ether into the carb throat with the throttle wide open. Nothing. Tried ether into the clyinders direct. Nothing. I started with the low speed needle 1 1/2 turns open, and the high 1 turn open. Adjusting them did nothing. The plugs aren't wet with fuel after all the pulling. The compression is a bit on the down side, about 80 lbs each. If it ran with all the old stuff in it, including a carb float that was broken in two, why won't it even kick now???
