Results 1 to 7 of 7
  1. #1
    Question 1953 elgin 7.5 hp , twin cylinder
    Does anybody know the oil mix for this? Also I'm looking for a gas cap that lets air into the tank?
  2. #2
    Exclamation Re: 1953 elgin 7.5 hp , twin cylinder
    mixture is
    16: 1 Found the cap, thanks! Can I use any gasket for the gas glass bowl . Thats the last problem I have, before she runs, I hope? Thank you!!!!!
  3. #3
    Default Re: 1953 elgin 7.5 hp , twin cylinder
    Just got a 7.5 and wondering if you still do the 16: 1 ratio
  4. #4
    Yes, got mine working and ratio is 16: 1. Great little engine!!
  5. #5
    What about using gas with ethanol mixed in it?
  6. #6
    I have a 1954 Elgin 7.5. I have been using "Amsoil Saber 100:1 outboard oil" at 40:1. I'm scared to go much less than 40:1 but have been doing so for a couple of years. It is the everyday motor for my sailboat so although it doesn't get long haul use it does get used often enough. This has virtually eliminated the smoke and makes starting easier.
  7. #7
    Join Date
    Sep 2012
    Location
    N Wisconsin
    Posts
    151
    Avoid it if you can, you motor was not engineered for today's blended gas. Try to locate straight un-blended fuel
Similar Threads
  1. old 4hp twin cylinder merc
    By node1 in forum Mercury Mariner Outboard Forum
    Last Post: 08-25-2010, 06:26 PM
  2. 1953 Evinrude 25hp Big Twin project
    By signalmessiah in forum Johnson Evinrude Outboard Archive
    Last Post: 07-31-2007, 07:28 PM
  3. I have twin Volvo sxbs need to install twin helm steering
    By rick in forum Volvo Penta Gas Archive
    Last Post: 10-31-2002, 03:15 PM
  4. Old Sears elgin 2 cylinder
    By snipe in forum Outboard motors archive 2000-2004
    Last Post: 07-28-2001, 10:14 PM
  5. How to set points on big twin Evinrude 2 cylinder 1957
    By seasand77 in forum Outboard motors archive 2000-2004
    Last Post: 11-08-2000, 07:32 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
