MarineEngine.com - Your online store for all types of marine engines and boat parts.
PHONE ORDERS
Monday - Friday
9:00 AM - 5:00 PM EST
Click for TOLL-FREE Number
Secure Online Payments
Special $9.95 Flat Rate Shipping
(800) 209-9624 | Home | Contact | Shipping | Returns | Cart View your shopping cart.
Search by Part Number
Enter engine/drive part number.
Original & matching parts for sale.
Manuals & Accessories
Shop by description, item number
or manufacturer's model number.
Why shop with us? Check our reviews! Why Us & Reviews   Boat Repair Forum Boat Repair Forum   Boat Video Gallery Video Gallery
Results 1 to 3 of 3
  1. #1
    Default Etec 90 Hard Start and Quit at High RPM
    2004 EVINRUDE E90DSLSO
    Hi: The engine ran OK for the first day out this spring. But the second day was less successful. It started only after many attempts, idled poorly, and when I did get it out on open water, it went to nearly full speed for about 2 minutes then bogged down and refused to go above 2000 RPM. No warning lights.
    Since then I have got it running OK once. I thought it might be fuel. But a few amateur questions anyway:
    1. What might make it drop from nearly full speed to 2000 RPM?
    2. When the engine is running, should the fuel filter (mounted within the engine cover) be full, or will there be air there?
    3. With the noise baffle off, I can see two butterfly-like ports like the ones in an old time carb, when should these open? Only high RPM?
    Thank you for any help.
  2. #2
    Join Date
    Apr 2009
    Location
    Perth, W.A., Australia. Residence 35 Lower Donnelly River
    Posts
    231
    Default Re: Etec 90 Hard Start and Quit at High RPM
    Etec 90 2004
    They were absolutely a waste of time after crank shaft copped it!
    Australian ones suffered like you have stated.
    Nasty Things down Under!
    Upgrade to 2011 version.
    B
  3. #3
    Quote Originally Posted by collector_inspector View Post
    Etec 90 2004
    B
    Done.
Similar Threads
  1. High pressure water valve etec 250 hp 2007
    By sofimar in forum Johnson Evinrude Outboard Forum
    Last Post: 01-03-2010, 01:50 PM
  2. Etec 75 OR Yamaha 60 High Thrust for a 15b rib
    By alanplattdc in forum Yamaha Outboard Forum
    Last Post: 09-21-2009, 07:34 AM
  3. Etec 75 OR Yamaha 60 High Thrust for a 15b rib
    By alanplattdc in forum Johnson Evinrude Outboard Archive
    Last Post: 09-18-2009, 05:56 PM
  4. Hard time starting 2007 150hp Etec
    By Bass Slayer 7 in forum Johnson Evinrude Outboard Archive
    Last Post: 04-18-2008, 10:16 PM
  5. 1984 99hp Quit running wonbt start
    By hummer in forum Johnson Evinrude Outboard Archive
    Last Post: 05-30-2007, 11:35 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
