sgruebs870
Hello. I have a 1960 QD-61 Johnson 10hp outboard that has a bad prop shaft seal. I went to the local marine shop and purchased the prop shaft seal that is suppose to fit my outboard, but it doesn't. It fits around the shaft, but is too small for the housing. I cross referenced the prop shaft seal part number with several other marine shops and websites and they all matched. Did the part number change over the years, or could a previous owner have swapped the lower unit with a different model outboard? I heard, and may have heard wrong, that some 9.5hp Johnson lower units were interchangeable with some 10hp Johnsons. Any help will be greatly appreciated. Thanks!!!
