MarineEngine.com - Your online store for all types of marine engines and boat parts.
PHONE ORDERS
Monday - Friday
9:00 AM - 5:00 PM EST
Click for TOLL-FREE Number
Secure Online Payments
Special $9.95 Flat Rate Shipping
(800) 209-9624 | Home | Contact | Shipping | Returns | Cart View your shopping cart.
Search by Part Number
Enter engine/drive part number.
Original & matching parts for sale.
Manuals & Accessories
Shop by description, item number
or manufacturer's model number.
Why shop with us? Check our reviews! Why Us & Reviews   Boat Repair Forum Boat Repair Forum   Boat Video Gallery Video Gallery
Results 1 to 4 of 4
  1. #1
    Join Date
    Jun 2010
    Location
    LESVOS Island - GREECE
    Posts
    6
    Angry Johnson 90HP V4 Model 1999 no spark in any cylinder! (MOD BJ90PLEEB, SN G0453259B)
    The engine does not start after winter storage. No spark at any cylinder. The engine cracks and the battery is new and full!
    Kill switch tested! Remote at neutral e.t.c
    The story is that the engine could not start with no spark after winter storage. One day I tried again and it started and run for 15 minutes.
    After that day it does the same. It does not start with no spark in any cylinder.
    Any Help will be appreciated!
  2. #2
    Default Re: Johnson 90HP V4 Model 1999 no spark in any cylinder! (MOD BJ90PLEEB, SN G0453259B)
    Did you get any help?
    I have the same problem with my Engine BJ90PLEEB...
  3. #3
    Join Date
    Jan 2012
    Location
    Giessendam, Zuid-Holland, Netherlands, Netherlands
    Posts
    102
    Test the ignition system according to the Johnson service manual. Or ask a dealer to do this, it is a quite simple test (with the correct equipment).
  4. #4
    Join Date
    Sep 2006
    Location
    Baton rouge, La, USA
    Posts
    2,304
    disconnect the kill switch under the cowl.....there is a green and black wire coming off your power pack with an inline connection.....check the small 2 wire plug from the trigger to the power pack for a pushed back pin....they will run making a tip to tip connection instead of being fully connected and then all of a sudden go dead...you may have to disconnect it and turn the plug from the trigger sideways to see a pushed back pin...make sure you have a good ground on the engine... i would use an inductive timing light for a start to make sure it was a fire problem...how old is the gas?...you checked it for lack of fire at the start of the problem....after you got it to run and it then failed did you check it again to see if it is still a fire problem?
Similar Threads
  1. Water in Cylinder 90Hp Johnson V4 CE model
    By Kingy68 in forum Johnson Evinrude Outboard Forum
    Last Post: 02-03-2011, 08:45 AM
  2. 1999 90hp Johnson
    By budmanhunting in forum Johnson Evinrude Outboard Forum
    Last Post: 09-03-2010, 04:43 PM
  3. 90hp Mariner 1988 3 cylinder intermittant spark problems
    By zeek in forum Mercury Mariner Outboard Archive
    Last Post: 01-03-2007, 02:07 AM
  4. 1999 Johnson 90hp J90PLEEB
    By swflcracker in forum Johnson Evinrude Outboard Archive
    Last Post: 07-01-2006, 07:30 PM
  5. 1999 Johnson 90HP OverHeating HELP
    By SkinnyWater in forum Outboard motors archive 2000-2004
    Last Post: 01-01-2003, 10:40 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
