Was given this little outboard from the RV Camp manager where I camp/fish. Great for trolling but problem when revving up to get off the lake quick if wind picks up. I cleaned out carb, replaced fuel line. Engine shows little wear and no abuse. It runs fine at lower speed but when I increase to mid/full range, after about 5-9 minutes the motor starts to stutter intermittently and then soon shuts down completely. Then it won't restart for 10-15 minutes. And during this time if you pull the throttle it doesn't feel normal, like it's binding. I've been told it's symptomatic of the engine overheating, but the water tube spouts out a steady stream of cool water even when the outboard is shutting off. The cylinder head around the plug is warm, but I can continue to touch it without discomfort at the time the motor is shutting off.
Does anyone know what can cause this? I had it into one shop and they said since it was pushing out a good stream of water, and the cylinder head is not overly warm they couldn't figure out why it has the symptoms of overheating.
I don't know if I should pay to get another opinion or just junk the motor. But wish I didn't have to as it seems in such great shape otherwise.
Thanks,
Doug
Thanks,
Doug
