kountzelightdiesel
Ok I wanted to start a new thread for this because I think we gotten a little off course.
My 86 3.0l is still stumbling or hesitating coming off idle, I worked on it all weekend spent plenty of money and it is better but still not fixed.
I started with the basics new points, condensor and spark plugs all properly gapped, set the dwell, and adjusted the timing. Problem still there so I attack the fuel system... New fuel filter, replaced the intake gasket adjust carb. problem still there. I found the coil had been wired backwards so I changed it around runs much better still wont take the fuel off of idle. I remove the carb and disassemble it when I have a "Eureka" moment the inlet ball and passage under the the acc. pump was completly blocked and the venturi cluster mounting was warped causing it to not seal. I clean everything replace the venturi cluster reassemble and install. The engine cranks good cold comes up to temp readjust carb idle is smooth hit the throttle and she falls on her face. I back out and bring her up slow at about 1050-1100 rpms it will take the fuel no hesitation.
I am at a loss I really don't understand what I'm missing any thoughts?
Also the timing tab on this engine is badly corroded does anyone have a pic of what it should read I can make out all the notches and 12 and the word before but I'm not sure which notch is tdc.
