I have a '77 Merc Thunderbolt 500, I installed a new lower unit last year only to find out that the reverse lockout rod was missing. This is a long shaft engine with that little 5" or so extender between the shaft housing and the lower unit, s/n #4803973.
I purchased a new-old stock reverse rod and I tried to install it today. Up inside the driveshaft housing, there is little plastic winged piece that is a guide for the shifter shaft and the reverse lockout rod. When I install it, the shafts are parallel and seperated by maybe 1/8" at the most. When I try to install the mid spacer section, there is a round hole where the shifter shaft and the reverse lockout rod go down thru. There doesn't appear to be enough room to get that shaft and the lockout rod down thru there without them binding and being forced together. If I remove the plastic guide from up above, I can get it ON, but it still seems too tight.
The mid section and the plastic guide are original to the engine. The mid section has 2 pins that prevent me from being stupid and installing the piece upside down. Without the reverse lockout rod, I had the lower unit on last year and the motor running with no problem. The odd part is that if I lay the winged plastic on top of the mid section where it would normally sit right above, it is obvious by the holes that it would never fit right. It almost looks like the mid section should have a notch in it to allow room for the reverse lockout shaft.
This is the last thing that I have to do to this boat to get it wet, I completely gutted it last year and rebuilt it. Needless to say, it never got wet last year and thsi issue has frustrated me to no end. I'll bet that I spent 4 hours in the on/off rain today with no headway! BTW, I have a manual on CD, its about useless on this issue.
