TIP ,replacing exaust manifold gaskets V6 or V8
Bt Doctur
Silver Medal Contributor
Or using the longer riser bolt ,start that in a middle hole to support the manifold. Install the 2 outer bolts
with a few threads and remove the support bolt. You want the manifold to be away from the head slightly.Take the gasket and notch the 2 end holes from the bottom so they slip over the bolts. Use a spare bolt for size. Slip the gasket in between the manifold and head hooking the ends over the bolts.install remaining bolts and tighten to specs.​
