Results 1 to 2 of 2
  1. #1
    Question Clinton 5HP Model K500 3106 B Can anyone help me with how to run my fuel lines on these?
  2. #2
    Join Date
    May 2009
    Location
    Quartzsite, Az, usa
    Posts
    489
    Default Re: Clinton 5HP Model K500 3106 B Can anyone help me with how to run my fuel lines on these?
    Your fuel line from the tank and shut off valve (which must be closed when running on the remote tank) go to the back facing barb on the carb. The remote tank hose goes to the front facing barb on the carb. The remote tank fitting must not leak, or you will get air to the carb instead of gas. Sometimes the little barbs would break and there were models with out the remote tank fitting. The remote tank model is fed with the "bladder " fuel pump in the flange of the carb and the reeds to that pump are under the plate the fuel lines go on.
Similar Threads
  1. need to purchase a needle and parts for my Clinton K500 carburetor
    By nathanbaker in forum Clinton Outboards
    Last Post: 05-21-2011, 11:37 AM
  2. Montgomery Ward Sea King 1973 5 HP Clinton K500
    By technoid in forum Clinton Outboards
    Last Post: 01-02-2011, 05:52 PM
  3. Montgomery Ward Sea King 1973 5 HP Clinton K500
    By technoid in forum Montgomery Wards Sea King
    Last Post: 10-02-2009, 06:10 AM
  4. Need help old clinton model #AJ91100
    By labsports1 in forum Clinton Outboards
    Last Post: 04-05-2009, 05:32 PM
  5. Plastic fuel tank rubber fuel lines amp grounding
    By cwebb in forum Archive 2003-2007
    Last Post: 12-03-2006, 12:50 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
