markwright
I recently installed a rebuilt crusader 454 in to my Mainship. the motor will fire right up but seems to idle very rough. I will alter the rpm and the idle will seem to get smoother then I will change the RPM and it gets rough again. I replaced the plugs and wires with the rebuild. I have sprayed WD 40 around the intake and the carb looking for vacuum leaks and none were found? i am not sure what to check next? Right now the motor is only timed by ear....I was planning to get the timing light on it when the boat is in the water. even wtih that though I cant imagine it would run the way it does??
