Hi all, i wanted to say thank you for all the feedback i got on the charging problem i had.Well after all that it came down to a few things.1- using a cheep wallmart multi meter it was acting up. 2- helm volt gage cheepy after market again giveing incorrect volt reading.I did put new recterfier on and used a good shop volt meter. allso took the deep cell batt i had hooked up and replaced with a new marine batt butt not a deep cycle one .the shop said not to use a deep cycle. I thought that my second batt off the pergo batt switch should be a deep cycle seeing i run all my assesoryies off of it .Butt the teck said that may of been some of the problem.After all said and done put the new batt in and again using a good meter the charging system was putting out correct readind.allthough the helm gage still was reading a bit on the hi side but i will change it out till then i will just compersate on the incorect reading. so i am good to go .and a fishig i will go. thanks to all tony.
