diver_dave
Advanced Contributor
Is the choke tie wrapped open? If not, are you sure it completely opens?
..."I replied to your post already.."
Sorry--I missed that.
How "weak" are those two cylinders?
Jeff
A couple of things stood out for me on your recent posts. What carbs are you running? In your first post you reported 6 psi fuel pressure, in your recent post you report 8 psi, that seems a little high to me but may be acceptable for your carb. Check carb spec. Also, re your timing readings, do you have 8 deg base timing? And do you have an advance curve you could reffer to?
I had the same backfire problem on a OMC - V8 a few years back . Engine came into my shop, we pulled the heads sent them out for R&R came back still hand the problem. we pulled the heads back off, this time I took them back to the head-shop. The machinist said the heads were fine. I said show me the valve spring pressure. Marine valve springs have a higher
spec. than auto - "His it's OK" was 75 lbs, book spec. was 85lbs min ! we replaced and shimed to the right spec and
wala---- 4500 rpm . Be sure your head-shop understands "marine" heads.
Never approach anything faster than your willing to hit it".<
I'd bet the ignition is the culprit. Being as he's swapped the coils and the complete distributor, that only leaves the wiring. my two cents.
wow, so a bad tach was the root cause? This is one of the posts you file away in the back of your mind and never forget.
thanks for posting all the details.... I know it was a painful process, we've all been there.
Bob
Pull the coil wire from the distributor and see how strong the spark jumps to ground as the engine is cranked. If you have a strong spark from the coil wire but not at the plug wires, check for a problem with the cap or the rotor. Keep both hands away from sharp objects....that red stuff leaves a nasty stain!
only suggestion would be to try a Colourtune sparkplug,in different cylinders.its shaped like a spark plug,but you can see through it,actually see the combustion.
