Results 1 to 3 of 3
  1. #1
    Default Bearing buddy removal
    I tried to replace the bearings in my trailer, the bearing buddies are in the way but I cant seem to remove them. Are they pressed in? Any help would be great
  2. #2
    Join Date
    Nov 2005
    Location
    Chesapeake, Va, US
    Posts
    1,111
    Default Re: Bearing buddy removal
    While turning the wheel tap the outer edge with a hammer.
    Bill H PTC USN Ret
    A manual is a cheap investment.
  3. #3
    Join Date
    Sep 2008
    Location
    Hague, Virginia, USA
    Posts
    4,971
    You might want to try some PB Blaster around the hub, let is soak awhile, then try tapping with a hammer as ibnfshn suggested.
    CHawk 25 DLX
Similar Threads
  1. Removal of bearing carrier nut
    By lcboom in forum Mercruiser Sterndrive Archive
    Last Post: 07-27-2009, 07:11 PM
  2. Gimbal Bearing Removal
    By yeoman100 in forum Mercruiser Sterndrive Archive
    Last Post: 05-20-2008, 12:33 AM
  3. 57 GSi bellhousing bearing removal
    By txsnowmobiler in forum Volvo Penta Gas Archive
    Last Post: 08-11-2007, 01:09 AM
  4. 1972 Gimble bearing removal
    By pleyden in forum Volvo Penta Gas Archive
    Last Post: 03-06-2006, 06:10 PM
  5. Shaft bearing removal
    By Eug? Gaumond in forum Archive 2003-2007
    Last Post: 12-28-2000, 06:54 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
