MarineEngine.com - Your online store for all types of marine engines and boat parts.
Order by phone
(800) 209-9624
Monday - Friday
8:30 AM - 5:30 PM EST
Safe Online Orders
Comodo Enhanced Security
Special $9.95 Flat Rate Shipping
Boat Repair Forum Boat Repair Forum     Boat Video Gallery Video Gallery
Home | Contact | Shipping | Returns | Cart View your shopping cart.
Part Number Search
Shop by engine/drive part number.
Original & matching parts for sale.
Manuals & Accessories
Shop by description, item number
or manufacturer's model number.
Click for Force Manuals and Parts!    Click for Chrysler Manuals and Parts!
Results 1 to 3 of 3
  1. #1
    Default 1990 90hp force popping sound out the third carb.
    when engine is at an idle the third carb is poppin. goes away when throttle rises and then starts again. Ran some engine tune through the carbs and it didnt change anything. Does anyone know what im talking about. Thanks
  2. #2
    Join Date
    May 2010
    Location
    Sebastian ,Fl
    Posts
    1,275
    Default Re: 1990 90hp force popping sound out the third carb.
    Fill out the profile.Do a compression test.Should close on all 3.Any more than 10% post that.Then reset the air screws.
    In the water, in gear,motor warm.Before you begin,1st turn the air screws in till they just bottom out(GENTLY) then out 1 full turn.Remember what each was set at and if it's way different post that.
    Then reset them,turn each in till it starts to miss.cough,buck then out 1/2 turn.Repeat on the other 2.J
    PARDON THE WRITING, FOR SOME REASON I CAN'T USE PARAGRAPHS. THE SENTANCE'S ALL RUN TOGETHER !!!Ethanol is messing up a lot .It's delaminating the inside of older hoses causing clogs in the carbs/injectors and fuel filter.
    Oh yea DON"T buy any parts from boats . net Worst company on the net.
  3. #3
    Join Date
    Sep 2010
    Location
    Jersey Shore
    Posts
    2,453
    Pull the carb and take a close look at the reed valves.
Similar Threads
  1. Popping sound coming from engine at full throttle
    By dave5496 in forum Mercruiser Sterndrive Archive
    Last Post: 08-04-2008, 10:04 PM
  2. 1990 90hp Force Carb Synchronization
    By Goin'slow in forum Chrysler Force Outboard Archive
    Last Post: 07-04-2008, 06:43 AM
  3. Carburetor Back Fire or Popping Sound
    By bill_000 in forum Mercruiser Sterndrive Archive
    Last Post: 06-12-2008, 08:27 PM
  4. Weird popping sound out of the carb
    By dustinj in forum Other Gas Inboard Mfgs IO and Sterndrive Questions
    Last Post: 03-17-2008, 07:11 AM
  5. 1990 90hp force outboard
    By bobbyrod in forum Chrysler Force Outboard Archive
    Last Post: 02-28-2008, 10:23 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
